KTM 250 4
I believe there is one coming, anyone know anything about it? Hope it doesn't rattle my 250F
Simmo
[This message has been edited by Simmo (edited 03-21-2001).]
try to find the january edition of Dirt Rider and you'll have all the info that is available right now. sorry if i offend, but i hope that ktm will walk the dog on a yamaha.
-Dan
90 dr250
94 ktm 125
Location
Kali - You should come to SpodeFest and ride my shortened YZF. Once you try it out you'll see it makes the decision on what bike to buy much simpler when you know you can MAKE the bike fit you
Location
Keep in mind there will be nearly 4 inches of sag in there as well.
I thought I read in here I think, that the KTM 250F will be a sleeved down 400. Is that still the case?
Dash
Dash, As for the 250 KTM, that is the rumour, how much truth is in it is yet to be seen. I wish someone from Europe who has seen one would chime in here and let us know.
Lets just say that i know for SURE that its NOT a resleeved 400sx/exc. Maybe at 1st it was to be a resleeve job, but they decided to to redesign the engine. Now, its indeed a new
engine.
Amandio J.S. Bacalhau < '96 KTM LC4 620 >
mmmm c'mon guys whos got some specs?
twin cam? I heard husky are doing a twin cam 250 mxer.
I think yamaha are still light years ahead because of the 400-426F's development.
Bring em on i say cause the 250 4 class is pretty small around here
Simmo
"Principal item of the fire-new width unit 250 is naturally the just as fire-new engine. Extremely compactly it failed, with four-vierventilkopf and two cam shafts, which operate acting valves via " super flat " cams unusually short-stroke. Via a special MV Agusta patent takes place the operation of the valves in innovative way, how numbers of revolutions of 13.000/min become problem-free possible! Devoted in the case of 58,3mm stroke, at present one holds 73,8mm drilling a capacity of 249,4ccm thereby with approximately 34PS at the crankshaft or 30PS at the rear wheel, the engine weighs with e-starter only 27 Kilos!"
How much power does the 250F have at the flywheel or rear wheel?
MMM DOHC 4 valve look out shes a goer, and it has 6 gears!
Basically looks cool, but
Gemessenes Kampfgewicht fahrfertig ohen Benzin: nur 115 Kilo!
My German is not the best, but I'm thinking that says 253lbs. a little heavier then a KTM of much more displacement.
Measured combat weight ohen gasoline: only 115 Kilos!
I guess thats the wet weight, isn't that light? whats the wr250f weigh wet?
Basically the new KTM 250 four stroke that is supposed to be coming out is just a sleeved 400RFS motor unlike the YZ250f that is a totally redesigned and not a 426 with a smaller displacement.
The desinger of the KTM 250 four stroke died while working on this project so it kind of put the project on hold for a bit.
In my opinion it will be primarily a woods bike and a fine one at that.
BenjaminPQ
1979 RM125 (long gone)
1995 CR125 (sold)
1999 KTM 300MXC!!!
Based on the current technology and what the public is willing to pay for a motorcycle, I would say that it will be difficult to get a e-start, dohc 4-stroke that is durable and weighs much less than 250 lbs ready to ride. It looks to me like Husky has done a good job, the bikes (2 prototypes) did very well at the 2000 ISDE. If they go to electronic solenoid valve (like Formula-1 cars), then the weights will drop.
does it matter whether it is a husky ktm or husaberg? personally i'm tired of the yamaha hype. If you take a ktm and make the suspension more friendly you would have a better bike than anything that ever came out of japan. And even if the bike is a husky, it is a fact that husky is owned by ktm, the 400rfs is a version of the husky 400. i say bring on the ktm and let a good time be had by all
-Dan
90 dr250
94 ktm 125
God bless yamaha for getting the suspension almost perfect, anything softer and you have a bike that isn't suited to mx as far as i'm concerned ie ktm, maybe they'll fix it!
lets face it, so far yamaha has the goods and a couple of years lead, everything else is just speculation so far.
Simmo
