MXTex
417
Don't let this happen to you. :yikes: This is what happens when you let a lower shock bearing on a Kawi go too long. I've replaced this thing so many times I just got tired of it so I let it go. When I did finally go it to replace, this is all that was left.
MXTex
417
Honestly, I don't know. But I think about a year. I've had the pivot works replacement bearings sitting in my garage for about 6 months; so I've known of the issue for a while. Just too lazy. :uh:
JasonWho
2,109
I just looked on www.buykawasaki.com to see what all was involved. I have a PivotWorks kit for my lower shock bearing, but it is cheaper to go OEM through www.ronayers.com on my '94 KDX200. I looked on www.ronayers.com, and here is what I found for a 1998 KX250:
Total parts cost is $21.68, plus $7 shipping, for a total cost of $28.68.
Superceeded Part
Part Number: 92152-1139
Description: COLLAR
Price: $3.54
Part Number: 92093-1436
Description: SEAL
Price: $2.91
Part Number: 92046-1192
Description: BEARING-NEEDLE,16BM22
Price: $7.73
Description: SEAL
Price: $2.91
Superceeded Part
Part Number: 42036-1351
Description: SLEEVE
Price: $4.59
You may want to check into that next time it comes around. I know those are high wear, frequent replacement items.
Hope this helps!
SULLY
147
Don't know about the technicalities, but boy on that paper plate sure looks good. A splash of chilli sauce and some chips(fries US) and salad and I reckon it's worn so thin I could eat and pass it thru unnoticed!
ScottS
478
For extra bonus points identify all the objects on his bench in the background
Hondaxrguy
573
That bearing goes bad VERY quickly on my KX too. Last 2 times I've tried to grease it, the needles have fallen out. This time I ordered my bearings from a bearing supply shop. The local guy I tried didn't have them in stock, so I went searching online. They were under $5 a piece. I got 4 of the larger bearings (hk2016) at $4.68, and 2 of the smaller lower shock bearings (hk1612) at $4.16. Shipping was only $4.90. I ordered them from www.bdiexpress.com
Jeremy
I think before I install the bearings, I'm going to go to a marine shop and get some good waterproof grease. Anyone have any suggestions?
JasonWho
2,109
Here is my guess on the table contents:
alternator box
tub of margarine - I am hoping it is a parts container now
three tire irons
a nut cracker
the base for a rolling shop vac
hose clamp
ScottS
478
you know it looks like the subframe with airbox still insatlled to me- but could be a shop vac too,
I saw two tire irons but wasn;'t sure if the other one was an iron or a scribe- is that waht you are calling a nutcracker ?
there is a white bucket behind the alternator box
JasonWho
2,109
No, there are three tire irons. Are you seeing a box to the left of the alternator box? The thing I am calling a nutcracker is what you are calling the subframe.
ScottS
478
I think I see a plastic pail (just the top of it) to the right of the alternator box.
