Replacement Throttle Housing?
rcers
95
My son smashed his throttle housing on his 220 this last weekend.A new one from KAWASAKI is almost $60.00.I have seen other aftermarket twist throttle assemblys for $20-$30(MotionPro Turbo Throttle),will these other aftermarket assemblys work with the stock cable or do you have to buy special cables?
THANKS
rethnal
659
I believe they require the MotionPro cable made for that throttle assembly. It is usually in the description. Where are you buying from?
