Ok, here goes: I ride this 01CR125 in the woods, tight trails, engine is tight (less than 20 hours on original top end), mods include PC pipe, PC spark arrestor (repacked fresh). I've gotten advise on jetting from many of the readers and I've tried a multitude of combinations ie. pilots from 37.5 to 60 and all inbetween, mains from 360 to 390 same as before, 2068, 2070, 2170 needles clipped from 1 to 3, A/S from 1 to 2.5, mucho variations. 32:1 HP2 w/93pump, BR9EG and BR8EG and 600 ftSL.
My issue is no bottom hit (and excessive spooge which I can live with). I feel air may be the issue. Without major mods to the engine I want to know if anyone has had this same issue and any luck finding the low hit. I have heard of using the v-force low tension reeds and cutting the slide. My belief is the reeds will allow the engine to gulp more air when initial load is placed which may be my cure. The slide cut could cure some spooging but then I may run too lean with gas to air ratio (I'm slightly afraid of seizure). Anybody with real results?
