I've got oil leaking from the black rebound ajuster knob on the top of my forks. The parts break down shows a o-ring on the adj.
and and I can see one up inside the fork cap. Has anyone else had this problem and can someone tell me how to fix.
This is normally because when the forks were filled with oil-the tube where the damper rod sits was also filled with oil.This should be empty of oil.It causes oil to seep out the rebound knob.
