tightwoods
- Nov 23, 2000
- 87
- 0
I'm a first time KTM owner but decided to take a chance on orange.
Like Tony the Tiger sez - "It's GRRRRRRRREEEEEEEAAAAAAAATE!!!!
Ergos perfect for taller rider - I put the factory tall seat on which has a less comfortable cross section shape than stock but I stand a lot so it doesn't really bother me. Geared a bit too tall for around here (North Central PA) - will go up 2 teeth on rear. 2nd gear is too tall for steep climbs and tight twisties - had to slip clutch too much. Then, because of wide ratio tranny, 1st would be too low/slow. Will do 90 mph in 6 gear no problem. With larger rear can use 2, 3, 4 to advantage and 1st will be even better for trials stuff. Stock bars are awesome but too wide. Can only remove ~ 3/8" each end before perches hit bend - NFG! I've got to find a bar that will let me cut down to at least 28" bare. After adding grips and bark busters you're back to ~ 29.5". Does anybody know of any mfgs who have this? Moose has a Burleson bend that is supposed to be 30" stock but I don't know how much more can be cut down and still allow proper controls mounting. I didn't have time to touch /set up suspension. Felt OK but was very stiff. Front wheel was ricocheting off roots and small rocks - very tiring. Guys riding behind me said bike was bouncing all over the place - looked hard to control. It was but bike kept tracking forward regardless - instant self correction to stability very evident. After a tough, technical ride on Sunday (I couldn't get undressed/dressed/out of bed without wife's help I was sooooooooo sore!!! Beer and ibuprofen didn't help), one of the guys who has a 400 EXC rode it. Said suspension way too stiff. All suspension issues very easily correctable. Cornering is very precise with good feedback. Doesn't under steer in tight stuff like I was expecting - definite plus. No need to change triple clamps. Powerband is nirvana - ultra smooth response right off idle. Strong, smooth, controllable pull to high rpm. Can leave it pinned if don't feel like shifting but seems to work better if use torque and short shift. No tiring power hit whatsoever. Very quiet stock muffler is a keeper . Anybody who wants more power should get the 525 and leave muffler stock. Less sound = more ground. Perfect power delivery for my terrain and off road riding in general. Wouldn't want the 525! Jetting is probably too lean but will fix that easily. Brakes are excellent. Rear needs some adjusting - too much pedal travel before any response. Front is truly amazing - progressive feel and power. On steep downhills where XR600 lever would be buried to grip, KTM will put me over bars! Hydraulic clutch is easily 1 finger and doesn't fade or go out of adjustment. Engineering, fit/finish excellent. Overall package is wonderful. I had some doubts but not any more.
:thumb:
:thumb:
