mkelly04 said:1. It will make your engine dirty...... If I remember correctly there is a bold right behind the frame so it is hard to change the gasket without pulling the engine.
2. That depends on how the bike is running, if it is fouling plugs or running lean then re-jet the bike.
hot125mod said:thats 32:1
jet your bike
50:1 is a joke.
gap your plug
dsmdarryl said:The cover is easily accessable of the left side of the engine.
It does foul plugs a quite frequently. I reduced the oil mixture to 50:1 with amsoil. I was using lucas at 4 ounces to the gallon.
One tank of gas and it hasn't fouled a plug on 50:1.
mkelly04 said:Ahh, I assumed it was the cover for the actual kips valve on the front.
Get a gasket for $2.00 and replace it.
As far as the jetting there are plenty of threads on the subject so do a search. On my bike for 6k feet of elevation I believe I ran 2 sizes smaller on the main jet and 2 sizes smaller on the pilot jet.
I ran Silkolene pro 2 sx 45:1 The bike never fouled plugs.
Oh, what plug are you running? I would suggest running the eix plug instead of the eg. It is more expensive but they run a lot better.
