uhlanmc
32
I am jetting my yz and I've only gone one size down on the pilot jet, and 2nd needle clip from the top. When I started the bike, the Idle was way up, and no matter what I did, the bike wouldn't come down. Top end? Compression was 150. I'm pretty sure this is the problem. thanx.
Spine_Thrust
149
Did you kick the bike over several times when testing the compression? Usually takes about 10 or so kicks to get it to its highest level.
Did it do this before the jet change?
Does the throttle slide move freely?
DLHamblin
268
Also make sure you don't have an air leak (not sure if you removed the carb to jet or just loosened and rotated). A small air leak can cause this as well.
