motojunkie
88
Yes, I have a 2001 520SX, and I added the Oberg Sports 18MM offset triple clamps, and they greatly improve cornering. They tend to induce a little headshake, which can be cured by moving the rear wheel back a little - I added 2 links to the chain, and at the same time added a 2 tooth larger sprocket. Also, you'll may need to make some fork adjustments, mine felt a little stiff after the change, I took out 2 clicks of compression, and it feels much better. Check out www.obergsports.com they don't list the 18MM offset on the web site, but they have them.
lawman
762
i have a set i'll sell, a scott's, with the upper mount for the damper & oversized bars, & with brackets to mount handguards to the upper clamp. e-mail me if interested.
lawman
762
hey schlava, good to hear from you, buddy! btw, i like that p/c pipe well enough that i ordered a s/a for it so i can use it in enduros.
i couldn't remember what i paid for the thing so i just called scott's, they said the clamp set for oversized bars, with the top bar mount set up for the damper, in 18mm offset, is $349 + shipping. i paid about $50 for the bar mounts, incl. longer bolts, from kevin's cycle, + shipping. i used this setup for a couple of months. i'll take $325, i'll ship & insure ups ground.
