1978 TS250 Front fork susp
TCW
The front suspention is completely gone, i can fully compress it by putting my weight on it, any way to rebuild it?
A lot of times new seals and fluid will cure this problem. If not, try new seals, about 1/2 oz additional fluid in each fork than called for in the manual and a 1/2" spacer at the top of each spring.
Other than that, you probably need to find new springs and seals.
