1983 HONDA CR250R - Crankcase Oil or ATF?
MAKAVELI
14
I need to know:
-Oil Capacity (Side says 300 somethin)
-What Oil to use? Weight?
-What about Using ATF? I see that alot. Its an old machine and probably has never had ATF in it. Good Idea? Do you completely use ATF (as opposed to oil and some atf, or vise sersa)?
Thanks so much,guys,
Rob
:ride:
76GMC1500
Uhhh...
Use what you want, they all work. Fill it until it comes out the check bolt, don't worry about the capacity on the side. My CR says 600cc, but it really takes 800 cc if you fill it to the check bolt.
