ok so after this bike has been sitting in my garage for almost 5 years know, i finally bought the new parts to fix the bike and sell it. I replaces the Jug and piston since there was a gouge tookin out of the piston and the Cylinder walls.
The bike fired right up and ran very strong, the only problem is it wont just sit and idle the bike is always trying to go. If you pull in the back break the bike will stall out. To keep the bike in one spot with out moving you gotta hold break in and give it gas. So like preloading the bike at the starting gate. How can i fix this.
Also we broke off the Oil Plug on the side of the motor (Kickstart side) is there a better alternative to replaceing this instead of useing the plastic OEM plug.
