MotoTrials
- Jan 31, 2004
- 9
- 0
The air box cover on my 2001 Gas Gas EC250 does not join well with the side panel. You can see a decent size gap. Do any of you have a similar problem? Should I be concerned with getting water and dirt inside? I was thinking about sealing this off with tape but I'm not sure where the air typically enters at.
Also, have you tried the Trial Tech computer on a Gas Gas? I want to get an odometer, but their web site doesn't specify one for Gas Gas. I think their inverted fork mount kit should work with the front brake rotor. If you have this brand, do you also use their dashboard mounting kit and if so which one? I think the bolt spacing is 100 mm.
Thanks,
Matt
Thanks,
Matt
