damndirtbiker
Hi, I am new to this site and looking for some help please. I have a 2002 CR250 and I'm replacing my clutch. But I can't figure out how to get my basket off. I've removed the bolt and the center basket, but can't get the outer basket off. Is there a tool for this, or do I need to pull harder? Thanks for you help.
MXFastGuy
611
I don't know about the '02+, but thru '01 I know you had to take off the whole right side engine sidecover, not just the quick-change cover... The basket was just slightly larger than the opening.
tony91
493
^^^^ The entire right-side cover must come off. Remember to drain the coolant. If you go easy, you should be able to salvage the gasket.
damndirtbiker
Just home from work, I see what you're saying about the whole right side cover. Thanks! Can't wait to get it off and see how much damage I did to the cover trying to pull the basket through. :(
