bschleuning
- Aug 20, 2003
- 15
- 0
Just a few quick questions about this kx125 2002, just bought it at a decent price, bike is very clean and runs awesome, somethings that i noticed and wonered if they are normal or not, first is that when you put it in gear it seems like it clunks pretty hard, the clutch is fine and has clean tranny oil in it, and it shifts good when going thru the gears, second is i noticed a greyish/black substance floating in the radiator, not a lot , the radiators are clean other than a bit of this floating at the top, third the overflow tube for the power valve leaks a few drops when you stop and park it, i just changed the tranny fluid and there is no signs of coolant in there, changed the anti-freeze also, this bike was purchased in denver co. and jetted accordingly, The elevation where i ride it is about 1500 feet less than denver, the bike has no bog or dead spots, its wide open right now when pinned would a over rich condition cause the powervalve overflow to drip, any known problems with this bike ill ride it awhile and see if the little bit of black stuff comes back in the radiator, or coolant finds its way into the gearcase, as far as the hard clunk when put into gear anyone have any comments or answers..they'll be greatly appreciated...thanks
