- Jul 3, 1999
- 2,726
- 1
2003 KLX 125 float height
Ok, so Amys KLX stopped running and I'm checking it out. Turns out it is not getting gas. Took off the carb and sprayed out all the passages and such. It was a little gunky. Still no gas, can't even blow through the gas port. So I Take the carb off again and reinspect and clean the float valve. No dice! It's now getting late so in desperation I tweak the tab holding the float valve up. Presto starts every time! But now it floods as soon as I open the throttle. But the float has a non bendable plastic stop so float height does not appear to be adjustable :yell: So other then trial and error does any one have any idea how to set this thing?
