acutemp
197
Yes a large body PWK carb will bolt right in. It is a real tight fit and if you are using the stock reedcage you will need a larger clamp. You have to use the top off of the stock carb also. I installed a modified 39mm carb on my KDX tonight with my rad valve and it was pretty snug but from the little testing I did it will be well worth the trouble:) --Dan
