Hi everyone! I'm new here, just got a 83' kdx 200. on thursday i'm gonna pull the topend off and install a new gasket kit because the base gasket is blown. when i put everything back together how should i torque the head down? any info would be great, thanks!
Of course snug the bolts down so they are like finger tight, then go like left to right, top to bottom for example. The upper left bolt, then the far lower right, then the upper right then lower left. evenly torqure them as your go till you reach your torque spec and use a torque wrench!!
