dave89b
62
hey guys just bought 2 bikes. the 86 has a blown engine. ( i mean blown )
and an 88' with a good engine(so far)
when i bought the 88 the guy said he just took it to the shop to have the carb cleaned. well i rode it all day today and it was really hard to keep it running smooth.
i was gonna pull the carb apart and go through it but was wondering if i could just throw the carb on from my 86' ( just went through it the other day) without any problems.
i have the clymer manual and it seems the 86 has a mikuni carb and the 88 model use's a keihn. i kind of like the mikuni carb more because it seems to be a lot more simple. can i use it without damage to my engine?
also on both bikes the expansion chamber leaks at the head. the o rings are there but it still leaks. i tried high temp rtv but it still leaks. its like the the pipe is bent so the pipe isn't sitting flush with the head. i thought the pipe was just bent but both bikes are like this??
i want to upgrade the exp chamber and put a silencer on. but i;m not sure if a aftermarket exp chamber will solve my problem.
anyone have any ideas??
dave89b
62
i am also planning on doing the top end . should i get the wiseco top end rebuild kit off ebay or just go cheap? its like 144 bucks for the wiseco.
what else would i need if i got the kit. it says it comes with everything but i doubt it really does.
i've been doing a lot of searching and answered a lot of my own questions.
julien_d
1,788
It's not a bad price on the kit, because it comes with piston, rings, piston pin, and top end gaskets. The only other piece you need is the small end bearing. I'd go ahead with the top end before you start troubleshooting the fine tuning. Check the rod/crank for play while you have the cylinder off.
dave89b
62
thanks guy's i will do the top end first. what should i do if there is a bunch of crank/rod play? i don't want to tear into the bottom end just yet.
also what should i do about the exhaust? it leaks a lot right at the cylinder head
sr5bidder
1,463
are you using springs?
have you checked the silencer for a mouse nest?
your frame tabs and exhuast tabs could need to be tweaked for a square fitting system
when you do the top end you can epoxy the exhuast hole if its worn and reshape it for a tight fit
dave89b
62
yep, using springs, no mouse nests. i've heated up the exhaust and tried tweaking it, but with no luck.
did the rear wheel bearings yesterday. a lot easier than i thought!
glad2ride
1,071
I'd say to buy new o-rings and a new crush gasket, plus some silicone.
If someone let it rattle around in there with a sloppy fit, it will have been widened. What's the technical term for "wallered out"? :-) In the game "paper, scissors, rock", paper beats rock. In this KDX game, a steel pipe beats an aluminum cylinder. :-(
sr5bidder
1,463
I think wallered out is the proper term if used anywhere south of virginia.
dave89b
62
ain't no kawasaki stealership around here. theres a honda one though
i don't think its wallowed out to much . its tightly held on with the 3 springs, just not a the right angle so it leaks
sr5bidder
1,463
at some piont maybe a trail was wallered out and a PO hit it and had a yard sale and bent something
yard sale = a bad wipeout or crash. where crap flys everywhere.. (a term learn from watching a video possibly nitro circus)
dave89b
62
was out riding tonight and my headlight went out :( about 10 miles back in the dark going reallly slow
the wire came un-soldered at the contact. i managed to leave the leave bulb out in the woods.....so what kind of bulb do i need?? i can't seem to find it in my shop manual
dave89b
62
i'm prettty sure my top end needss a rebuild. but will it do more damage to the bottom end to keep riding it? or should i not run it till i do the top end.
dave89b
62
took a drive earlier and walked the trail i was riding and somehow found the bulb! soldered the wire together and put it in and it works!
julien_d
1,788
The pipe is great in my experience, ymmv. Not much difference in loudness over the stock pipe, but a more clean crisp note. The silencer is quite similar to the stock unit, maybe a touch quieter. My buddy runs one on his but with the stock pipe. Problem is, it has no sparky. It's a straight through silencer only.
dave89b
62
i just want to buy it so my exhaust doesn't leak at the head. the stock pipe doesn't fit right at all so its really loud.
what do you mean by it has no sparky, its a straight through silencer only?
