I have adjusted and checked all the easily accessible engine parts. My bike still has very little power - 1st gear is useless (gets to maybe 5-8mph) and no gear has the power to pull the front wheel up. I just put in new reeds and am running a 150 main and 55 pilot, unsure about needle. I did a compression test and get a consistent 150.
I replaced the valve needle and re-adjusted the float level but the carb still is constantly overflowing. The bike runs extremely rich and I suspect that this may be the majority of the problem.
Also, I pulled the pipe off and checked the kips - as much as I could see. The shaft coming out of the case turns at about 1/2 throttle as I think it's supposed to. However, when I look at the side valves with the motor running (cant see the main because of the exhaust) they are bouncing all over the place.
If anybody has any ideas or suggestions please let me know. Trying to figure this thing out is making me crazy, but I don't want to give in and take it to a shop.
