nosstang
6
At what point should you do a rebuild based on a compression test? I have about 125-130.I also have been haveing a spark plug fouling problem.Could this be my problem??? Thanks for any suggestions you guys could give me.
BLACKeR
76
125-130 shouldnt even start. even assuming your compression tester is broken, and your not testing properly, your low. time for a rebuild. i bet youll be surprised how fast your bike is all of a sudden.
BLACKeR
76
is it a motorcycle tester or an automotive tester? that can make a difference. the method ive heard, and use is to kick several times with the throttle held open. i basically kick till the needle stops moving. make sure the tester is screwed in tight too.
