Hey every one, I have question about the condition of my wr's gear box. I'm using the Honda HP trans oil 80/85W and change it about every 3 rides or so. As you know the Honda oil is clear and red, like ATF, when gose in, but when I drain in it looks like strawberry milk. I'm pretty sure this isn't right. The tranny shifts fine, except for occasionally hitting neautral between 1st, and 2nd gear. I thought maybe the crank seal on the right side was bad, letting by-products of combustion mix with the tranny oil causing this condition. I'm replacing that. Dose anyone have any other thoughts? Thanks in advance.
