Guys i got a 05 220 with the stock bars and grips.
Been trying to mount these hand guards without messing anything up... :bang:
Has anyone mounted a set of these on the stock bars ?
Any info or pic's sure would help...thanks
THill, are you mounting rally gaurds (plastic wrap around) or a Metal bar all the way around with deflectors on top of it? Also, what length are your bars? Witch gaurds sis you buy?
Thought id post a little follow up about these guards.
The problem i was having was the stock bars have a plug welded into the ends , you either got to drill and grind all that plug out or use another set of bars...
So if your going to mount a set on stock bars it's not going to be a simple bolt on deal....
