If your looking to put a rubber seal between your filter and boot why not do the best thing(in my opinion) buy a UNI filter with the rubber strip built into the filter. I have used these many times and found that they are easier to keep clean then Twin Air. But if even if you want a seal that will keep out garabge then some grease around your filter going onto the boot will work really good.
