jonnyriabov
- Oct 27, 2005
- 90
- 0
Well, I went to change my new used 2004 yz 250s trans oil today, for the first time since I purchased it (4th ride), The darn drain bolt must have been over torqued the last time, because it wouldnt budge....I managed to strip the already worn corners off the bolt with my socket, and then mutilated the rest of the bolt with the old vicegrips.......I decided that the only way it was coming out would be to go next door and have my neibour weld a nut on to the end.......he suggested I try his damaged bolt remover first, and with the bike laying on its side, and a good solid pull out it spun......What a lifesavor tool, I strongly recomend it......
Hey I picked up two new drain bolts and washers today from my local yam dealer ( one to replace and one for a spare) and the replacement washers are made out of fiber or something, they said that yamaha has replaced the old aluminum washers part number with the fibers ones....is this true? or did the girl sell me the wrong washers?
jonny riabov
jonny riabov
