I seriously doubt it. At 150 lbs, I ride a YZ125X and it screems. My son, at 220 lbs, says it lacks power for him.So I'm looking at getting a Yamaha ttr 125, I'm currently around 150kgs (315lb) I believe.
Will it be able to carry my weight?? Someone please help!!!
What about a 150, keep in mind I'm a beginner rider so I won't want to be going flat out at the moment. I'm more worried about the bike itself. Don't want to spend money on a bike only for it to break because it can't handle my weight lolI seriously doubt it. At 150 lbs, I ride a YZ125X and it screems. My son, at 220 lbs, says it lacks power for him.
I'm around 170cm tall - 5'8. A friend has a wr250f and it's too tall for me. I want something I can touch the ground with both feet. He also believes a 250 will be too powerful for me, but as I explained I'm quite heavy so I don't have many other options than to get a 250 do I.To be clear... you are 315 lbs? Yes, you are too big for a TTR125. How tall are you? As far as a "full size" 125cc or 250cc (4-stroke) motocross bikes; they are the generally the same height a a 450 ... so depending on your height that will be a much better fit than the small TTR, not to mention a LOT more power than a TTR, which is a trail / back yard bike.
Most new MX bikes are setup from the factory for the "average" size rider, somewhere in the 150 - 170lb range if I recall, so mater what bike you get, it's going to be under-sprung for a bigger rider. You can still ride it and have a lot of fun as a beginner, it will probably feel pretty fast ... but keep in mind it won't handle as well as it should and it sure won't deal with hard landings... a sure way to get bounced-off big time.
Very little. I learnt the basics on a Suzuki jr80 but as that is a small bike I can assume that would be fairly easy to learn on compared to a 250 or similar.How much experience do you have on a motocross bike, or any bike for that matter?
Have a look at the beta 300 xtrainer or gasgas 300 ranger. The gasgas has better suspension.
Power delivery is more mellow and they have lower seat height
