Another silencer question...w/pics
CarpetMan
14
Sorry to hit the silencer thing so soon again, but I need some help and can't find the exact answer in a search.
Here is a picture of my Pro Circuit silencer, http://www.pbase.com/image/27739575.jpg
As you can see it is in bad need of repacking, I don't think it's ever been done. I took out the three 8mm bolts at the end but could not get the core out....nor could a get a grip on it with anything worth a flip. Do I have to drill out the rivets on the other end?? If not, how do I get a grip on the inside of the core to pull it out?......I'm lost!
KAY DEE EXER
629
I have a FMF which looks similar in design and if I were to guess, I would say "YES" you have to take the core out from the riveted end. Someone else will correct me if i'm wrong.
Twiztid One
312
you dont need to drill out the rivets , soak the end seam with wd40 and let it sit for a little bit . all it is the end cap is coroded a little , put a screw driver in there and with a rubber mallet or block a wood just keep tapping it all around to get it to break loose .
