My antifreeze is leaking slowly thru the weep hole in the bottem of the engine. Is my water pump going bad or is it just the gasket, Or maybe something else wrong.
It's got a bad water pump seal. Check the engine oil for contamination. If there is water in the oil (it'll look like chocolate milk) you will have to replace both seals on the water pump shaft. Also check the shaft itself, if it has a grove in it, get a new one. Make sure you install the new seal facing the same way as the old one came out, if you put it in assbackwards it will leak. Good luck.
