egzlilgituarboy9
- Jun 16, 2009
- 9
- 0
ok so i just rebuilt my 2005 kx250f top end and it wont start and i dont know why. it is timed correct. all i get is backfires about every few kicks. any help would be awesome
egzlilgituarboy9 said:i never checked the vavle clearance though. why would the valve clearance make it not start?
:whoa: :whoa: :whoa:gage_cr250 said:i had the same problem with mine when u ut a new top end on the compession changes and the carb needs to be tuned to the right specs..
now why would you say something like that and scare him ;)Ol'89r said:Unless you have a valve seat grinding/cutting machine, valve guide reamers, spring testers, spring compressors and the knowledge to use all of that stuff then, yes, you should send your head to a shop.
Even if the valves seal properly, they should be replaced if they have too much time on them. If the valves have too much running time, they can come apart. This will cause major damage to your engine if not caught in time.
Replacing the stock valves with Kibblewhite stainless valves is a good idea. The stainless valves will outlast the stock valves and they don't break like the factory valves can. You will need the complete kit with valves and springs.
You should have an hour meter on your bike. This is the only accurate way to know how many hours are on your engine.
oldguy said:now why would you say something like that and scare him ;)
This was an engine with less then 10 hours on it
egzlilgituarboy9 said:ok so i just rebuilt my 2005 kx250f top end and it wont start and i dont know why. it is timed correct. all i get is backfires about every few kicks. any help would be awesome
