- Nov 13, 2001
- 1,178
- 0
Product: Boyesen Super Bowl
Pros:
- It is bigger then the stock float bowl.
- Don't need a overflow.
- Allows more gas into the carb.
- Eliminates bogging when bike is leaned over.
- Comes with gasket
Cons:
- Expensive ( I paid $20 for minebrand new tho :) )
- Drain screw design for Keihin carbs doesn't allow the screw to properly screw in all the way so it reaches the o-ring and you must screw it in very tight to keep it from leaking.
- Putting the carb screws is a pain cause of the oversized bowl shape and you must make sure you don't cross-thread it.
1-10 Rating
__ 6 __
This is just my review so some people may have different comments on it
Pros:
- Comes with gasket
Cons:
1-10 Rating
__ 6 __
