Anyone have any good real life case repair success stories - what did you use/how well did it hold? i have had cases tig welded and the like before but this time I'm faced with an interesting dilemma...I've got a street bike apart and there is a Cone shaped casting in the case that cracked - a shaft that holds the shifter in place that slides into so I need to get it fixed to take the slop out...I was thinking either some type of epoxy or having the hole filled with weld and then drilled out. Any ideas?
