Replaced the stator coil and getting good readings--403 ohms. Still no sparky. Stator shows good ground to chassis and good circuit at the plug ends of the red/white and black wires(when disconnected from the CDI). This is where it gets wierd. The CDI matrix says with positive lead to black/yellow and neg. to black.white(kill switch) infinity---ok. black/yellow to white/red(stator charge) infinity---ok. BUT black/yellow to black(ground) should be closed circuit and I'm getting infinity. AND black/yellow to black(ignition coil) should read 2.8-3.7kohms and I'm getting infinity. Is there any doubt that the CDI is fried or not??? Everyone I've talked with says the readings you get are meaningless and the only way to tell is to replace---that's expensive guesswork in my book. Any ideas?
