Clarke clear tank is stained, any way to clean?
Montana300
123
Has anyone found something that will clean up a clear tank from turning colors? Not a big deal on my KTM, but a friends YZ is less than pretty with the opaque tank becoming brown tinted, any ideas?
dell30rb
Uhhh...
Dec 2, 2001
1,510
my stock white cr80 tank is black in the places I grip it with my knees, its not that big of a deal but it seems like its in the plastic! it wont come off
Hucker
996
Its the gas/premix slowly venting through the tank that makes it discoloured. The only way I have found on my RM to bring a little of the colour back is to sand it with a high grit sandpaper, then eventually work your way up to a wet sand. Its a pain in the ass if you ask me, if I could I'd jusst cove rit up with some stickers :)
Unit74
494
try filling it up to the top with Av gas and let it sit for a few days. Then remove and mix 50/50 with pump gas and run. I have not done this myself, but a friend of mine swears it works.
Lorin
948
Having a white bike, I can relate. The best thing that I have found in keeping the clay and red dirt stains off the bike is paint thinner. It works well if you do it regularly, but may require a lot of work if you only do it occassionaly. For times when the tank gets really brown, I use good ole' rubbing compound and\or soft scrub and follow up with paint thinner. Only works if you stay with it at regular intervals.
