I just wanted to know what clutch kit would be best for a cr250. The plates in mine are burnt out and i need a new kit. I was looking around and found EBC and Barnett. I was wondering whats the best and if its not one of those, what should i go with?
used the stock, ebc, and barnett in my 03 and keep coming back to the barnett mostly for cost and durability. I would use stock if it werent so expensive, you may notice a slight flywheel effect going to aftermarket heavier steel plates. I have used several ebc's and only had one kit- the kevlar kit, glaze up, but constant clutch abuse can do that. I do keep the oil full and clean. I ordered a super cheap - tusk kit as a spare may just put it in to see if it can handle it.... :nod:
I used a EBC Clutch on my 97 CR250 and hated it compared to stock. I had to readjust my cable free play alot during a ride compared to the OEM Honda clutch. My advice is to stick with OEM Honda or go with Pro-X, which is apparently comes from the same supplier.
