meangreen 67
23
I have a 98 KX250 that slips in 4th gear when the bike is on the pipe. I can cruise around in 4th gear without problems. It doesn't slip in any other gears.
The problem started when I noticed the clutch slipping at the track 1 day. The rubber fill plug broke and was leaking oil. I installed a new White Bros. clutch kit and it still slipped. The oil was filthy after only 5 laps. I took the clutch apart, sanded the fibers on a glass plate, filed the clutch basket smooth(it wasn't that bad), installed kx500 springs and fresh Maxima 80 wt oil and it still slipped.
So I took it apart again. This time I had the clutch hub and pressure plate faces glass beaded, put in new OEM fiber and steel plates, the 500 springs and Bel Ray 80 wt oil. The clutch didn't slip after 6 laps. I pulled in to check the oil and adjustment. I went back out and the clutch started slipping after about 5 more laps.
I took it apart again, very carefully inspected and measured everything and couldn't find anything obvious. Actually I've taken it apart and inspected it about 10 times over the course of 3 months.
I was an auto mechanic for 8 years so I have pretty good mechanical ability and I have the service manual. This has me completely stumped. I called Hinson and they said it could be the basket but I dont want to spend another $200 and not fix it. The basket is still within spec after mild filing. Is there some way it could be trans related? It has never popped out of gear.
I have an 03 KX250 and am thinking about putting the entire clutch assembly (from the basket to the springs) into the 98 and vise versa and changing one part at a time until it starts slipping. That's if the clutch assemblies interchange. Plus it's gonna take a long time to test each part 1 by 1.
If anyone has any advise I'd appreciate it. Thanks.
flynbryan
1,066
Why are you running Kx500 springs? I would assume that its because the 500 springs are stiffer? That seems to be the only object in the assembly that is not OEM. I know its trivial, but give the stock 250 springs a try. Possibly the spring lengths are different and even though they are stiffer they're not long enough to actuate the clutch properly? You never know. Also what kind of lever free play are you running. I imagine you know to do this, but sometimes it takes stating the obvious to notice things. I would be curious to know what reasoning Hinson has to think that its the basket other than to sell you one of their products. :think:
Ray30+Vet
4
I had a YZ 125 slip only in 3rd gear and it was 2nd gear which engaged 3rd had rounded edges on the nubs? that would engage 3rd. In other words it had nothing to do with the clutch it was in the transmission. I hope this might help you. Ray
meangreen 67
23
flynbryan - It slipped with the White Bros. and OEM 250 springs so I figured I would give the OEM 500 springs a shot. I also took the complete clutch assembly to a MX motor/suspension shop (when I was having some fork seals replaced) and he told me everything looked ok. I tried excessive free play in the lever and it still slipped. Everything in the clutch assembly is to spec. Your right about the Hinson basket, even after talking to them it didn't seem like a basket problem to me. Thanks for the help.
Ray30+Vet - After I put the 2nd new clutch in I figured it had to be in the trans. But I've had my son's KX60 trans apart and couldn't see how that could cause the problem. But know you got me thinking. I should probably split the cases and have a look around. The bike is just sitting there and it's not gonna fix itself. But 1st I'll see if the clutch assemblies interchange between 98 and 03. If it slips with my 03 assembly it HAS to be in the trans.
Right?
If anyone else has an opinion I'm all ears.
Ray30+Vet
4
Well meangreen, when I first looked at the trans on my old YZ I could not see anything wrong so I replaced 3rd & 4th which are paired as one and it still sliped in 3rd. So I took a much closer look at how the trans actually worked and saw that 2nd would engage 3rd by moving almost inside of 3rd. So I pulled 2nd out and studied it closely and saw the small rounded edges on the nubs. On the new 2nd gear these same edges are sharp. So if you open the trans dont just look at the actual teeth on the gears study how they react to shifting and try to uderstand how 4th is engaged. I hope this will help you. Ray
john stu
790
don't worrie that your clutch is slipping in only 4th gear soon it will slip in all gears!!!!!do you have a service manuel if not get one maybe your missing a washer or somethings not asembled right
meangreen 67
23
john stu - I have the service manual. I have went over the clutch assembly with a fine tooth comb at least 10 times. It's been a major bummer.
Ray - Thanks for the help. It is kinda refreshing knowing someone else has had a similar problem. Hopefully I'll be able to work on it next week and I'll post what I find.
