antorider
17
Hi guys,
I will appreciate someone to tell me in which position go the thicker metal plates in the CR 250 1999 clutch assembly. As far as I can see, there are 8 friction plates and 7 metal plates. There are 5 metal plates the same thickness, the last 2 are thicker. So if we number the friction plates from 1 to 8, in between which ones the thicker ones fit.
76GMC1500
Uhhh...
Ok, it goes inner hub, friction, thin, friction, thin, friction, thin, friction, thick, friction, thick, friction, thin, friction, thin, friction, pressure plate. At least this si the case according to the microfilm. I don't actually think it matters where they go.
