cracked oil drain. right side.
thermo
51
2000 200 exc, had a heli coil it got pulled out. put in another and it leaked. i went to tighten it (just a hair) and a piece of the oil drain on the right broke off. what should i do? could i get this fixed? if so how? Or should i just jb it and use the left side only.help!
pentonman
13
I just jb welded the screw into my 250 after it stripped, I havent had any problems, Im just extra careful I measure out the correct amount of gera oil when I change it.
John
munch
293
Is this the small bolt? I stripped the smaller of the 2 so I retapped the hole to accept the same size of drain plug as the other side. Picked the plug up at my local dealership. Worked great.
