r6demon said:I THought this COULD be done by prising out the seal and then tapping the new one in.
Its been a while since Ive looked at this but I am sure it could be done?!?!
If your going to have to do the job anyway, I would definatly give it ago before splitting the cases!!
kdxquebec said:if you have a lefft side oil leak in the FW cover......
before split the case for nothing (like i did) remove the flywheel and look on the case area where the shaft go out.you will see 3 slots around the shaft.clean these slots with parts cleaner then sand a little then fill the slots with JBWELD .this will stop the 2 stroke engine oil leak.(98% sure)try this... maybe your seal is still good.this trick works for a lot of guys with 89-94 200. GOOD LUCK! :)
