I have a 1991 CR125. I am trying to change the fork seals because one of them leaks. I took one of my forks off the bike and took off the end cap, unscrewed the endcap from the damper rod, took the spring out, and drained the oil. I clamped the fork slider in the vise and attempted to remove the damper adjust bolt on the bottom of the fork. With alot of force the bolt will turn, but it will not come out. Also when I turn the bolt it's like something is getting stripped/chewed/wrecked because little flakes or "strands" of what looks like copper come out from around the head of the bolt. Should I just keep turning the bolt and it will come out or is there something wrong here??
Or better yet, can someone explain how to remove the damper rod and fork slider from the fork tube?
