nhoj said:I would like owners to add the following (only for KDX 200's)
Year of bike = 1995-2006
Main jet = 160
Pilot = 48
Clip position = third groove from top
Mix = airscrew??:1 1/2 +\- 1/4 turns out
Altitude = (sea or high up) 1000 feet
Temp = (hot - above 10 degrees C, Cold - below) above, of course
Mods = stock, including carb
Other =
float height: 16 +/-2mm
needle jet: N426-24C00
needle: R1174K 2AFKQ
starter jet: 78
slide (cutaway): #5
josefmd said:You mean go to 44:1 and effectively make it worse by making to circuit richer. Less oil means more fuel=richer jetting. From all I have learned from a lot of threads with regards to this subject, it's better to stick with whats recommened 32:1 and jet for that. The common method is going to something like 50:1 will cure plug fouling or excessive spooge/smoke, it dosen't, it makes it worse.
Yes, it can be.lemmy said:so you think spooge and plug fouling is caused by the bike running rich (by rich I mean too much fuel, I am not meaning too much oil)?
mudpack said:Spooge and smoke comes from burning oil, not from burning gasoline. You can reduce both by going to premium synthetics at 50:1.
That is...if your heart can take it.
Two-strokes engines will ALWAYS have some smoke and oil residue in the exhaust; there is no way to get around it. These are not four-strokes.
True. Oil residue in the exhaust system is unburned lubricating oil. This is the oil that is in the fuel. Two-strokes are ALWAYS burning oil....that's how they are designed.aussie smoker said:Mud pack im with you on the smoke, but spooge would indicate not all oil is burning ??
