Well, I'm pretty sure the rebuilt cdi will work, but I still have no spark. Tough to check the primary coil, but I'm getting 6000 ohms on the secondary and what looks to be in the vacinity of .1 ohms on the primary. Close to spec from what I've seen posted here---unless someone knows different, I'm all ears. Plug wire shows good continuity. Registering AC voltage coming from the stator coil. Very frustrating to chase this one down. Decided on complete teardown and inspection of all electronics and wires. Could be an intermittant short which is no longer intermittant. Strangly, the engine ran fine when it did run the last few times---for 30 seconds or so at a time--before finally not running at all, but now it sounds kind of funny when I kick it over. Maybe that's my imagination. Nothing banging around or anything, just a hollow compression sound...wierd.
Eventually I'll figure this out and then report on the cdi rebuild---whether it works or not. :think: Down but not out!!! Jay
