I went to change my oil today and the bolt was really hard to get off.. like.. much more than the 14ft lbs I torqued it to last time. but i got it off and drained the oil. Then when i went to put the drain bolt back in it wouldn't start to thread in. I looked in the hole and some of the threads had just broken off. i got most of them out but some are still in there.
So my question is, should i get a helicoil put in or do i tap out the hole to the next size and get a bigger bolt? I know with the helicoil the threads will be stronger than before and it probably wont happen again, but we already have a tap set and a bolt for it wont cost that much.
And last, what can I do so this doesn't happen again?
