gasgasbill
WHEN I HAVE MY CLUTCH PULLED IN AND MY BIKE IN GEAR IT WANTS TO PULL A LITTLE.WHY?? ALSO WHAT SHOULD I BE RUNNING IN MY TRANSMISSION?(OIL)WHAT KIND .
BILL L.
GlennP
311
Is your GG fairly new? It needs a little time for break in. Clutch tolerances are tight in the GGs and they use more plates than most bikes. What oil are you running? BelRay Gearsaver will make the GG clutch drag more for some reason. Run Spectro 80W gear oil for best results. If it still drags after break in back bleed the clutch through the slave cylinder fitting. When broken in and set up right, it should start in gear with a good kick.
Glenn
'00 GasGas XC250
Josh Cook
71
What fluid are you using in your clutch???
I run Motul 600 brake fluid in clutch & both brakes just like GGNA factory team. It works great.
They also run Spectro 80w 1 qrt.
