marcv125
727
i have a 2000 yz125 and have a fatty/shorty combo and also the delta 2 v-force reed valve. I was wondering if anyone had expierience w/ it.
marcusgunby
6,450
A friend of mine tested one on a 2001 Cr125 and got exactly the same result as on the FMF website-1hp more from mid upwards.Its alot of money for 1hp, but if you have done the usual mods and you have the money then go for it.One cheaper option you could try is a 38mm carb.
marcv125
727
i dont htink i would go with the carb just b/c on my yz125 i already have great low end and i dont want to sacrafice low end for top end power..
marcusgunby
6,450
very few mods will give you more power across the board so choose your mods wisely,it sounds like you are ready for a Eric Gorr 133/144 big bore conversion-about the same price as the ignition and if your 2000 has been ridden a reasonable amount it could probably do with a fresh cylinder.
spanky250
Mod Ban
Dec 10, 2000
1,490
Originally posted by marcv125
how reliable are the eric gorr motor mods. Does he do a better job than say fmf or procircuit?
FMF and Pro Circuit will give you a cookie-cutter job. Eric will tailor your mods to give you exactly what you tell him you are looking for. FMF did my cylinder, and I wish they hadn't.
marcv125
727
yeah i heard great things about eric gorrs motor. are the prices about the same or are erics alittle cheaper than the rest?
