MX-727
- Aug 4, 2000
- 1,810
- 13
I just tried the FMF Fatty, back to back against the SST. I actually rode with the Factory Fatty, but I find it hard to believe that the difference between the two Fatties would be much. I used the shorty with both pipes. The bike was my 2002 YZ250 with a milled head from Eric/Forward Motion, V-Force reed block/reeds and VP C-12/Yamalube 2R at 32:1
I warmed up and rode with the SST, which I've been using for the last year, at a tighter track with several jumps right out of corners. After getting a good feel for the track and bike, I switched the pipes. I could immediately feel a huge difference in power delivery. I was surprised because I didn't really expect there to be much of a difference.
The SST feels strong and has quite a bit of overrev when compared to the Fatty. The Fatty pulls much harder off the bottom and into the midrange, but it signs off a lot earlier. The differences were evident in the gear selections I used on the track. With the SST, I rode almost the entire track in second with the occasional shifts to third on the faster sections. The Fatty required/allowed me to ride in third and fourth in the same situations. Some of the slower corners were still easier in second, but an immediate upshift to third was called for. Most SST second gear jumps required third with the Fatty.
I had debated whether there was any reason to even consider the Fatty, but after riding it, I found that the two pipes really seem to compliment one another. I'll use the SST for faster, more open tracks such as Cooperland. The Fatty will be used on the tighter SX style tracks.
Understandably not everyone wants to buy two pipes, so if you are a revver, you'll like the SST and if you like to short shift, you'll like the Fatty.
