YZHooligan
- Oct 30, 2006
- 23
- 0
I rebuilt my forks, and it was a blast taking them apart, seeing how it works and everything.
I changed dust seals, fork seals and new oil.
After putting the forks back together, I was wondering if its normal to hear the oil flowing through the tubes when i move the forks around. Like..after they have been laying on the workshop table..then when i put them upright..I can hear the oil flowing down.
Is this normal? or does it mean theres too much air in the tubes? also when they are upright, and i put my weight on the tube to compress it, i hear a "squash" of the oil inside.
I followed the normal procedure of compressing fully the tubes and damper rod... then filling up...pumping the damper rod, pumping the outer tube..filled up with oil again...compressed everything again.. then repeating....
I adjusted to place stock level of oil in the forks(135mm)
Let me know anyway!!
thanks!
~rich
p.s. YZ250 (2002) bike
thanks!
~rich
