hoerter2158
I just bought a 1988 RM125 and the gas is leaking out of the overflow. I cleaned the carb. It still leaks. And now it wont start. Would a new needle and seat make it run and not leak?
Or what other options/ solutions do you guys got?
Rice#67
40
Sometimes the float gets stuck in the bowl, it's a pretty common problem. But usually when you take the carb apart it frees up. If it's all together right now, I would try tapping on the carb with something that won't damage it. Maybe a rubber mallet. Not too hard of course. If that doesn't work I'd inspect the needle and seat. It shouldn't have any groove on the rubber surface.
Dec 8, 2007
138
If tapping the carb doesn't work try taking your carb off. Take off the bottom cover. Push the float pin out and remove the float and needle. Pull the needle off the float. Reconnect the fuel line on the gas tank to the carb. Push the needle into the seat by hand (black cone first) and turn on the fuel valve. Try not to push it up very hard at all, but use about the same amount of pressure as the float would make. If it leaks, its the needle, if not then its something else, check the float needle tab, make sure its properly assembled.
