drkhartley
14
Ive just recently purchased my first bike and I'm experiencing a gas leak out of the carb. It seems to be coming out of the fuel bowl. Is there any way to stop it without taking the carb apart?
jb_dallas
498
You will need to take the bowl off of the carb. It is probably a stuck float or needle. Clean everything out with B12. I am assuming that you are turning off the fuel valve when it is not running...
jb_dallas
498
FYI - The post above was assuming that the gas is leaking out of the overflow line. If gas is leaking from the bowl itself, you may need a new gasket.
Tap the float bowl with a peice of wood or a soft hammer. Sometimes a peice of dirt will get stuck between the float valve and seat. If that doesn't help pull it down for a cleaning and inspection.
