Hello!
I have a YZ250, and I am in the process of putting togther the governor . I am confused on how to assembly the spring that goes between the governor rod and the power valve. The owner's manual shows the torsion spring ends crossed, and somewhat mated to the right most lever that is connect to the governor rod. There is another lever that is to the left of the spring that mates with the power valve assemly (rectangular groove fit). Where does this lever go relative to the spring ends? Should the springs ends be crossed? If not, I think I can put both of the levers between the spring end. However, the owners manul shows the spring ends crossed. When crossed, the left lever is outside of the spring ends. This doesn't make sense. In this case, the spring only grabs one lever. What do you need a spring for?
Please help, as you can see I'm confuse. Hopefully, I have not managed to confuse you as well!!!
