'00kx250spode
197
My service manual specifies that I grease the wheel bearings and seals but doesn't say that I should grease the axle or the inside of the bearings, sleeve or collars.
Should I apply a light coating of grease to these parts when I assemble or will it just get gunked up with dirt if I do?
Peer Lovell
I would coat the axle with a light coating of grease or anti sieze compound...particularily the rear axle.
This just makes it easier to remove. The same goes for the swing arm bolt.
I would avoid getting grease on the seals.
MikeT
4,095
11
Greasing the axle is a must!
'00kx250spode
197
Okay, thanks for straightening me out on this. I wonder why the manual doesn't say that I should grease the axle?
I've already re-assembled the swingarm. I put new bearings in. I'll pull that bolt out and grease it, too.
Are there any other axle/bolts that should be greased?
RM_guy
Moderator
7,060
214
North East USA
It’s a good idea to put some grease on motor mounting bolts. They tend to corrode where they pass through the motor.
70 marlin
2,960
DITTO!!!!!!!!!!!!!!!!!!!!!
a little anti seize is a good thing ! especially for the nexted owner! frozen swing arm bolts are no fun at all, been there!
